Dear all,
I was hoping someone could help me out on the following: I have transferred
BIL files from CDROM to my machine and tried reading them into Grass using
i.tape.other - however, the program is refusing to import the files and
produces a core dump when I specify the BIL file as the 'tape' to be read.
Is there some quick and dirty solution to this?
Philip Verhagen
philip@raap2.ivambv.uva.nl
R A A P
Plantage Muidergracht 14
1018 TV Amsterdam
The Netherlands
tel: +31 (20) 421 62 00
fax: +31 (20) 421 42 90
http://raap2.ivambv.uva.nl/home_eng.html
On Tue, 4 Feb 1997, Philip Verhagen wrote:
Dear all,
Philip Verhagen
Hi, Philip
I have successfully used i.tape.other this way before with no problems. I
assume that your BIL file is multi-band; if not, you can directly copy
the file to the GRASS cell directory and use r.support to build the other
needed files. I'm afraid that I don't know what could be causing the core
dump. Have you successfully run the i.tape.other command before?
-Malcolm
Malcolm D. Williamson - GIS Specialist E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
