Importing common bitmaps
ideally, we should have r.in.ppm since netpbm (pbmplus) is distributed
with grass. That way we don't need r.in.sunrast, r.in.tiff,
r.in.gif, etc. Am I correct in this thinking? Is there any instance
where ppm is not generic enough?
I agree, but I did notice that converting from PICT -> ppm -> sunrast
caused the lut's to get stuffed up a bit (this was in my Monash Uni
incarnation a few months ago).
Simon Cox
The lut's get "stuffed" because while PICT & sunrast use 8bit look up
tables, ppm doesn't, using 8bits for each of Red, Green, & Blue to represent
"True Color" instead. (Actually sunrast has a True Color flavor, but
the one r.in.surast accepts is the color look up table flavor.)
Because ppm is "True Color", you can get all those colors you never see
on your 8bit screen from your "continuous" raster maps if you use r.out.ppm,
then send the ppm to a slide recorder or other 24bit output device.
So in the conversion from ppm to sunrast, the
look up table has to be inferred from a look at the color distributions
in the ppm, and depending on the algorithm used, this is probaly where
it gets messed up. It would be better to go from PICT -> sunrast
directly, since both formats use look up tables.
However, I am unaware of any public domain "one step, all purpose"
converters (neither xv or alchemy are PD).
--Darrell
And that give me a chance to plug MY favorite FREE image tools,
SDSC Image Tools, from San Diego Supercomputer Center, available at:
ftp.sdsc.edu via anonymous ftp
in the directory: /pub/sdsc/graphics/imtools
This tool suite works with the following formats:
    bmp Microsoft Windows bitmap image file
    cur Microsoft Windows cursor image file
    eps Adobe Encapsulated PostScript file
    gif Compuserve Graphics image file
    hdf Hierarchical Data File
    ico Microsoft Windows icon image file
    icon Sun Icon and Cursor file
    iff Sun TAAC Image File Format
    mpnt Apple Macintosh MacPaint file
    pbm PBM Portable Bit Map file
    pcx ZSoft IBM PC Paintbrush file
    pgm PBM Portable Gray Map file
    pic PIXAR picture file
    pict Apple Macintosh QuickDraw/PICT file
    pix Alias image file
    ppm PBM Portable Pixel Map file
    pnm PBM Portable aNy Map file
    ps Adobe PostScript file (write only)
    ras Sun Rasterfile
    rgb SGI RGB image file
    rla Wavefront raster image file
    rle Utah Run length encoded image file
    synu SDSC Synu image file
    tga Truevision Targa image file
    tiff Tagged image file
    viff Khoros Visualization image file
    x AVS X image file
    xbm X11 bitmap file
    xwd X Window System window dump image file
And yes, Darrell, it works with standard input/output.
These are the tools you get (imconv being the most useful):
    Tool Description
    imadjust Adjust image colors, desaturate, brighten, etc.
    imcat Concatenate images into multi-image files
    imcltroll Cycle a color lookup table
    imcomp Digitally composite images
    imconv Convert between all supported image file formats
    imcopy Copy a portion of an image into a new file
    imfile Display image attributes
    imfill Fill a region of an image with a color or gradient
    imflip Flip an image horizontally or vertically
    imformats Describe image file format support
    imgray Convert to grayscale
    imhist Compute an image histogram
    immono Convert to monochrome
    impaste Paste an image into another
    imroll Cycle an image horizontally or vertically
    imrotate Free rotate an image
    imscale Scale an image up or down
    imshear Shear an image horizontally or vertically
    imsplit Split apart multi-image files
imconv is especially easy to use - if your image files have the right
extension, all you have to do is type:
and the conversion automagically happens, creating the new outfile.gif.
There are lots of options to these tools and so far there isn't much
I've found that they can't do (although read support for postscript
would be nice).
The disk space problem could be minimized if an r.in.ppm command
worked on stdin. Then, if users would find it simpler, a bunch of
scripts could be written for specific formats (e.g.,
    #!/bin/sh
    # r.in.gif (sans bells and whistles)
    giftoppm $1 | r.in.ppm -
    exit
[disclaimer - I haven't had a chance to look at the contrib
program that (Brown?) mentioned earlier - maybe it already
does this.]
--Darrell
The r.in.ppm I mentioned doesn't allow use of stdin, but that would be
great. I glanced at the code & it looks like it quantizes the colors it
finds in the ppm file to a maximum no. of colors of 32,768, which seems
like a reasonable number to deal with in a GRASS color file. (ppm files
could theoretically contain ~16 million different colors) I don't
know who wrote this - it's from SCS - anybody out there who could
accept credit/responsibility and verify this info?
- Bill B.
Bill Brown e-mail: brown@zorro.cecer.army.mil
USACERL - ECS phone: (217) 352-6511 ext 7676
PO Box 9005
Champaign, IL 61826-9005
See our visualization demo at URL:
http://www.cecer.army.mil/grass/viz/VIZ.html
