Hello:
I have purchased the USGS optional format 1:2million DLG CD. My goal is to
extract the state boundary(ies) for Iowa. I place the *.dlg file in the
/dlg directory of my (newly created) mapset and run v.import. I get no
error messages, but niether do I get a state border. I am quite certain is
due to some confusion with the projection. I have tried computing UTM
boundaries and Lat-Longs when setting up the mapset, but to no luck with the
final output. From looking at the X-Y information in the Ascii DLG, it
seems like it is probably plotting out of the range of the specified mapset
region, but I do not recognize the region boundries in the DLG header. The
lat-longs look familiar in the header, but the data seems to be in another
projection.
Could someone line me out on this import process. I know it should be
simple, but....
Thank you!
-Scott Grover
scottg@horne.com
