importing gld data
When patching dlg files together, map edges are not removed. Is there a way
to get rid of the map edges other than v.digit?
Any help appreciated
Stefan J.
sjaeger@resdgs2.er.usgs.gov
Try using v.spag -i, I *think* that removes duplicate lines...i.e. the
map edges. However, you still have to go into v.digit to remove the rest
of the map edges that are left...at least you only have to click
on all the lines once.
I'll be doing this, this afternoon on some dlg files I have if you need
anymore help.
Marcus
USACERL_TAC
P.S. Make a BACKUP before using v.spag!!!!
