I have just installed GRASS 4.1 on a SPARC 20 running Solaris 2.4. I used
the g.5 binaries as recommended in recent exchanges on this list.
Everything seems to be working ok except the graphics drivers. When I
start a monitor (I'm running motif) an empty window appears followed by
the message "Error - could not complete locking process..." and the path
for the lock.
Any ideas? (I have uncommented the X driver references in the monitorcap
file").
Thanks in anticipation,
Mark Lake.
for the lock.
file").
Mark,
Sounds like a permissions problem to me - check the permissions on
the $GISBASE/dev directory which should be owned by the grass user
and have drwxr-xr-x permissions.
Each of the fifo's should also be owned by the grass user and
be prw-rw-rw-.
The $GISBASE/locks directory should have the same ownership but
be drwxrwxrwx so that user's processes can write locking files
to it.
If you don't have a grass user, but are installing the binaries in your
home directory (I've done this on a solaris system), make all the files
owned by yourself with chown -R myname:mygroup grassdirectory.
David Wheatley
Department of Archaeology,
University of Southampton,
Highfield, Southampton, S017 1BJ
