Installation Tcltkgrass
Hello!
I have used Grass421(v19) on Linux 2.0.30.
I'd just downloaded new TclTkGrass 2.8 binaries and tried to install it.
I deleted my previous version, gunziped & untarred the new archive,
logged on Grass as root, changed to tcltkgrass dir and ran 'make'.
I just got this message:
make: /usr/local/bin/tclsh8.0 Command not found
make:*** [install] Error 127
I can find /usr/local/bin/tclsh8.0 and wish8.0.
When I type
cd /usr/local/bin
tclsh8.0
I get the message
It seems to me that tcltk8.0 in my system has some problems. I think the
installation was done following the instruction.
Please give me some solutions.
INOUE Kazunori
Water Resources Department_Pacific Consultants International
1-7-5 Sekido, Tama City,Tokyo, Japan,phone: +81(42) 372-6030,fax: +81(42)
372-6359
Hallo,
cd /usr/local/bin
tclsh8.0
I get the message
I am not an expert but i think i run into a very similar situation. Though
it was when i tried to run some binary compiled against libc6 while i used
only libc5. At the first glance it was unbelievable!
Anyway, i succeeded to install the grass50 binaries and prior to it the
tcl/tk sources. I remember only creating the symlint to wish from wish8.0
Hope it help a tiny little bit.
Imre Oolberg
PS to look at the libc is possible for instance like
prompt $ ldd /bin/cp
Kazunori Inoue wrote:
Hello!
When I type
cd /usr/local/bin
tclsh8.0
I get the message
INOUE Kazunori
372-6359
Make certain that the files tclsh8.0 and wish8.0 are:
1) executable ("chmod a+x /usr/local/bin/tclsh8.0" and "chmod a+x
/usr/local/bin/wish8.0")
2) make certain they belong to a user/group on your machine
3) make symbolic links ("ln -s /usr/local/bin/tclsh8.0 /usr/local/bin/tclsh"
and
"ln -s /usr/local/bin/wish8.0 /usr/local/bin/wish" )
and try again.
> Hello!
> When I type
> cd /usr/local/bin
> tclsh8.0
> I get the message
> INOUE Kazunori
> 372-6359
and
and try again.
I am having similar problems with grass 5 beta on COL 1.3, kernel 2.0.35.
grass tcltk is "built in" I think, but did not work. I have installed the new
library (ver 8.0) by untarring the archive from root, and get the message--
/usr/local/grass5/bin/tcltkgrass: /usr/local/bin/wish8.0: No such file or
directory
and then a repeat of the same message. I have checked ownership of tclsh8.0
and wish8.0 and they are grass.users. I set up the symbolic links recommended
above. The files are all executable by anyone. They are in the directory
cited.
I have read the scripts and cannot see what is wrong. Is Open Linux set up
differently enough to break the usual script? Or am I just missing something
obvious here?
