We have the following machines on which we would like to get Grass running
HP-UX oceana B.10.10 A 9000/770 2012964655 two-user license
OSF1 eisenhower.ecn.ou.edu V3.2 214 alpha
OSF1 lincoln.ecn.ou.edu V4.0 464 alpha
OSF1 ticonderoga.ecn.ou.edu V4.0 386 alpha
When we try compiling/linking grass4.1 on the DEC's it simply coredumps
while linking ...
Please let me know where I can find fresh copy of source code for grass4.1
which would run on the above m/cs.
Are there any modifications needed in the source code and what are they?
Also I believe that the source code at
ftp://129.229.103.1/pub/grass/grass4.1/release/source/
does have some problems with DEC Alpha's...
What is the remedy?
Thank you in advance !
Ian D'Abreo
Graduate Assistant
e-mail : imdabre@mailhost.ecn.uoknor.edu
Ian, David, other DEC victims
We are currently going through the process of upgrading
our Grass installation on our Alphas. We are using
James Ganong's latest version of the patches, and are
also doing the floating-point/null upgrade. We are part way
through the exercise so far but have not discovered any problems
we couldn't solve. We are keeping careful track of all the mods
and tricks, and should be in a position to post these to
the list in a week or so. If y'all can hold tight for a little
while, I think we should be able to help.
Simon Cox
__________________________________________________
Dr Simon Cox - Australian Geodynamics Cooperative Research Centre
CSIRO Exploration & Mining, PO Box 437, Nedlands, WA 6009 Australia
T: +61 9 389 8421 F: +61 9 389 1906 simon@ned.dem.csiro.au
http://www.ned.dem.csiro.au/unrestricted/people/CoxSimon/
