installing problem on SUN-sparc2
According to Darrell McCauley:
[replies directed to grassp-list]
> % man dlsym
> DLOPEN(3X) MISCELLANEOUS LIBRARY FUNCTIONS DLOPEN(3X)
> NAME
> dlopen, dlsym, dlerror, dlclose - simple programmatic inter-
*> face to the dynamic linker (problemmattic?)
> These functions are obtained by specifying -ldl as an option
> to ld(1).
Peter,
I've noticed this with compilation of other software and have never seen
this problem before Sun OS 4.1.1, but the work around is to edit the
Gmakefile in the directory where it bombed and add the -ldl in the
appropriate spot. If you find this problem with other directories,
then you may want to edit src/CMD/head/*
Can someone check the bug list for Sun OS 4.1.1 and see if this is
on there?
...stuff deleted ...
As far as I can tell you ... this is a 'ld' bug introduced at Sunos 4.1.2.
There should be a bug fix for that from SUN (or use the 4.1.1 ld ...).
Joachim
Joachim Wiesel, Institut fuer Photogrammetrie und Fernerkundung,
Universitaet Karlsruhe, Englerstr. 7, D-7500 Karlsruhe, Germany
Phone: +49 721 608 2316 Fax: +49 721 694 568
Internet: wiesel@ipf.bau-verm.uni-karlsruhe.de
