Integration in a DSS
I have been using Grass 4.1 on its own, using command line codes. I go
through the normal prompting upon typing 'grass4.1 <Enter>' such as
database and mapset. Now I need to integrate the execution of grass
tools and display capabilities into a small decision support system
(DSS).
My question is how to start grass up without the interactive prompting
for database and mapset? An alternative question is: how can I have
access to grass commands and displays from my other modules without a
bunch of programming on the grass source code?
(I am using Neuron Data's SmartElements to build expert system
knowledge bases, develop graphical user interfaces, and provide access
to relational databases. The expert system shell allows me to execute
external UNIX commands from the knowledge bases)
I can't seem to find anything in the manuals.
If anybody could help, I would be forever in their debt.
__________________________________________________________________
Mike Bender
Facility for Intelligent Decision Support in Water Resources
Civil & Geological Engineering
University of Manitoba
Winnipeg, Manitoba, R3T 2N2, CANADA
(204) 474-6746 [phone]
(204) 261-9534 [fax]
mike@fids.ce.umanitoba.ca
Mike Bender (mike@ce.umanitoba.ca) writes on 9 August 1995:
perhaps the following might be what you are looking for:
  % grass4.1 -help
  Usage: grass4.1 [-f] [-e] [-l location] [-m mapset] [-d gisdbase]
The -f means "fast startup," bypassing the beginning chit-chat
(see also 'csh -f'). Default is to use your last location, mapset,
and gisdbase, as found in $HOME/.grassrc. The -e means "fast exit,"
bypassing all of the clean up stuff. The others are self-explanatory.
see ftp://moon.cecer.army.mil/grass/incoming/new_startup.tar.gz
(just put it there a few minutes ago)
This contains some replacements for files in src/general/gis. After
putting the files there, you'll have to run gmake4.1 in that
directory. Warning: I have not tested this particular set of files
with 4.1. Rather, this was a file set that I prepared for and tested
with 4.2 (not yet released). However, this set of files is an update
to my previous contribution to moon which works under OSF (thanks to
Simon Cox) in addition to SunOS, Solaris, IRIX, etc.
I used this setup extensively at Purdue University (e.g.,
running v.out.sdts via WWW) and it works quite well. Also saves a lot
of time for normal GRASS usage (since many people always work with the
same mapset/location/gisdbase on a daily basis).
If you (and others) would like to see this in 4.2,
please express your interest to grassu-list (I think that the
jury is still out on whether or not this will be a 4.2 feature).
Darrell
James Darrell McCauley, PhD http://www.mcs.com/~mccauley/
16W518 Honeysuckle Rose Lane #214 mccauley@mcs.com
Hinsdale, Illinois 60521 USA tel: 708.655.0643
