Intergraph Import/Export
I know I have seen some discussion on this recently but could not find it
in the archives. Has any one had success at exporting Grass Raster files
to Integraph MGE (unix).
  I haven't tried this, but I would expect it to be possible as long as
  the GRASS raster file is uncompressed (r.compress -u) and you have all
   of the header info from the cellhd directory. Note how many bytes per
  cell are being used in the GRASS file (the "format:" in the header).
Has anyone had any success at importing
Microstation Design Files -- .dgn I think, into Grass. I believe the
vector files started out as dlg3 optional, were imported and enhanced in
Arc, and then moved over to the Intergraph MGE software. My problem is
that I would like to use the files in Grass, with other data I already
have and then give the whole data set back for use in the Intergraph MGE
system.
  Either a) have the files exported in DLG3 Optional format directly from
  Intergraph, or b) import the dgn file to Arc/Info using the IDGNARC
  command, and then export from A/I to GRASS. Sorry!
Any help with this conundrum would be appreciated.
Jim Klein
lkla@netcom.com
703-739-0972
Good luck!
Malcolm D. Williamson - GIS Specialist E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
