interpolation library
Dear GRASS programmers,
Compiling an interpolation library developed by Irina Kosinovsky
and Helena Mitasova I got some errors. It seems to be a specifically
IBM RS/6000 (which I use) problem. A compilation in data, tree and
interp was without any problem, however it failed in r.resample.tps,
s.surf.tps and v.surf.tps. I would appreciate any help.
Thank you very much in advance.
Jaro
grass>gmake4.1
  SRC = /home/grass/GIS/src
  CMD = /home/grass/GIS/src/CMD
  HEADER = ibm
  ARCH =
  GISBASE = /home/grass/GIS/ibm
  VERSION = 4.1 Spring 1993
/home/grass/surf.lib/r.resample.tps
  make -f OBJ/make.rules
        cc -s OBJ/main.o ../interp/LIB/libinterp.a ../data/LIB/libdata.a ../tre
e/LIB/libtree.a /home/grass/GIS/src/libes/LIB/libbitmap.a /home/grass/GIS/src/li
bes/LIB/liblinkm.a /home/grass/GIS/src/libes/LIB/libgis.a /home/grass/GIS/src/li
bes/LIB/libvect.a /home/grass/GIS/src/libes/LIB/libdig2.a -lm
0706-729 ERROR: ../interp/LIB/libinterp.a[libtree.a]: not an XCOFF object
The error code from the last failed command is 12.
Make Quitting.
Jaro Hofierka
Dept. of Cartography, Geoinformatics & Rem. Sensing
Comenius University
842 15 Bratislava E-mail: hofierka@devin.fns.uniba.sk
Slovakia hofierka@geoinfo.fns.uniba.sk
