Dear GRASS programmers,
[deletia]
0706-729 ERROR: ../interp/LIB/libinterp.a[libtree.a]: not an XCOFF object
The error code from the last failed command is 12.Make Quitting.
The library libinterp.a is not an XCOFF object. That is, it's not a x Common
Object File Format style file. The short of which is, you can't use it
unless it's recompiled for XCOFF format or is ported/compiled on a rs6000
machine.
rjones@halcyon.com OG+GOT;
GCS/S/O: d? -p+ @c++++ l+(+++) u+++++ e+(*) @*m-(----)
s++/++ n--- h--- f+ g+ w++++ t r- x+
Help! I'm a hostage of the US Postal Service!
