interpolation, rast.to.sites
On Fri, 2 Jul 93 18:02:28 EST, Simon Cox wrote:
I have been told that s.surf.tps is the "best" interpolater available
in grass. Why is this? My little experience with it has shown
that it is certainly not quick! What are its relative merits,
in comparison with idw and idw2?
What is the easiest way to convert a raster to a site list, so
that I can use the s.surf.tps interpolater? Is it necessary to
go via an ascii intermediate step?
Thanks for your advice.
Simon Cox
Simon,
I should plead guilty to an oversimplification in my comment to you about
interpolators in grass. I have been interested to read the various
responses on the grassu-list. Interpolation is a complicated issue, since
by its very nature one is trying to "put data where none exists".
I am currently heavily involved in using interpolators of all sorts, from
the idw type, through ArcInfo's tin, to s.surf.tps, to the spline software
developed by Mike Hutchinson which allows the use of independent variables
and/or covariates to "improve" the quality of a surface where something is
known about the relationship between your target data, and another
variable for which you have more data points, or even a grid.
Where you have sparse data, with a poor coverage, s.surf.idw does a good
job of giving you a surface which reflects the data you have, and nothing
more. But with sparse data, as I have from a model run on eastern
Australia, you get all sorts of unsatisfactory spots and regions which
you know do not reflect the real response surface. A tin (triangular
irregular network can do a little better job and readily restrict you
surface to a convex hull about your points, avoiding the strange
happenings which can occur for instance with splines.
I feel that s.surf.tps is a great innovation for grass ( the proposed
semivariogram kriging routine will also be a great addition), however it
does require a good even coverage of points, and fiddling with the tension
and other parameters to avoid the spectacular over- and under-shoots which
can occur in "data holes" and bare edge patches.
Dealing as I do with pasture models, requiring long runs of complete
climate data sets, inevitably I end up with a sparse set of data points.
However, if my model output is, say, dry matter yield, I have a good basis
for saying that independent grids of rainfall, elevation, temperature etc
will have quite predictable relationships with my model output. It is in
this area, that the algorithms which Hutchinson has developed, using
covariate relationships or independent variables, are hard to beat.
As I remember it, you were trying to contour a raster map. I guess my
experience with the grass raster contouring is the same as yours. Very
slow. Being an impatient soul, and flipping from program to program, I
prefer to regard rasters as simply arrays of points and to operate on
them, or subsamples of them, as such. Arc/Info has a nice "very important
point" (VIP) extraction routine to overcome the time and processing
problems of contouring, etc., very dense grids or point sets.
Interpolation is an area where different routines suit different tasks,
and sometimes the most simple say idw may be quite appropriate since it
represents the data, and does not OVERSTATE the precision.
I would repeat my suggestion that if you are unhappy with the speed of r.
surf.contour, try extracting a representative subsample of your grid cells
as points and see what s.surf.tps will do. You should have a good coverage
of points. The only reservation is that it would be better to extract the
say 10% of cells which statisically best describe the variation in your
data. I am not sure that there is a way to do this in grass.
Just a final important general point. Surface generation is all about a
better representation of sparse real data. The primary concern should
always be with not overfitting the surface, retaining a suitable humility
about the error levels in your surface, and the respect for the
limitations imposed by the quality, accuracy and portability of the base
data.
Apologies to those not interested in this, but I don't often burden you
with my thoughts
Michael Hill
Michael J Hill
Research Scientist
CSIRO Pastoral Research Laboratory, Armidale, NSW, Australia,2350.
E-Mail address: mhill@chiswick.anprod.csiro.au
With regard to this discussion on interpolation.
Yeah! Its not often the monotony of "how to" questions is
broken with some really interesting discussion. Thanks Simon
and Mike.
I have been trying to learn more about spline interpolation
myself. I have been primarily interested in kriging and when
I submit the PhD. next week I can get back to improving
s.surf.krig...but can anyone give some insight into Mike
Hutchinson's work. I have one or two of his papers on (under)
my desk, but I have to admit its all a little greek to me
but some of the equations look suspiciously (:wink: like kriging
equations to me...
anyone?
chris
