irix5.2 compile (RESOLVED, FATTO)
Would you mind posting or sending the Irix5.2 notes? I failed also to
compile those modules in my brief attempt.
Grazie,
Josh
Ir. Bart Cosyn
EC- Environment project
CRS4
Environmental modelling group
Via Nazario Sauro, 10
Tel +/39/70/2796280
Fax +/39/70/2796216
E-mail: bcosyn@crs4.it
Hi Bill,
On Fri, 7 Oct 1994, Bill Brown wrote:
Bart,
Here's a copy of my IRIX compile notes:
about the i.point,i.vpoint and i.orthophoto! It works fine no more
problems for compiling it!
Well about the monitor I can tell you that the problem was that I
forgot to uncomment the last :: any display so he did not took the
IRIS diplay. In fact a bit stupid but at least it's resolved.
Your notes were correct so I have to thank you for your BIG HELP.
      Thanks, Bart
Joshua Lieberman, Ph.D. josh@turb01.dmc.com
ENSR Consulting and Engineering wasser@world.std.com
35 Nagog Park, Acton, MA 01720 508-635-9500
