is ps.map working?
I have had no luck getting ps.map to run, though it compiled successfully
(including ps.icons) on a DECStation 5000. On the DEC (Ultrix 4.2a), I can
play 20 questions with ps.map just fine, but when I commit, I get:
set the printer and hit RETURN -->
pid 21542 (ps.map) was killed on a kernel access, at pc 0x40f174
Bus error
On the Sun 1+ (SunOS 4.1.1), I get an unceremonious Segmentation fault.
This is using the downloaded Sun binaries, not a locally compiled version.
Any ideas???
-kenn
Make sure that the postscript device description file (ps.devices)
is built and locatied in $GISBASE/etc/paint. See the man page for
ps.select for a discussion.
James A. Farley Technical Director, CAST/NCRI-SW
      12 Ozark Hall, Univ. of Arkansas
jim@cast.uark.edu Fayetteville, AR 72701
Voice: (501) 575-6159 FAX : (501) 575-3846
