William W. Hargrove wites
GrassHoppers:
Has anyone successfully used ps.map in 4.1beta successfully yet? I
cobbled up a PostScript device under $GISBASE/etc/paint/ps.devices (not
psdevices, as the g.manual page states) called phaserps like so:level: 2
page width: 8.5
page height: 11.0
top margin: 0.25
bottom margin: 0.25
left margin: 0.25
right margin: 0.25
resolution: 300and I can select it with ps.select, no problem. But when I try to use
ps.map, after answering all of the prompts, when I hit return, I get an
immediate Segmentation fault. It does write out the script file, if I
request that, but only creates a zero-length postscript file.Anyone know anything about this? It looks like a nice tool. Anybody
know an E-mail address forPaul Carlson, USDA, SCS, NHQ-CGIS?
I've had the same problem however when i run ps.map in the command line
form using a prepared input file i get ps output to the printer just
fine.
James A. Farley Technical Director, CAST/NCRI-SW
12 Ozark Hall, Univ. of Arkansas
jim@cast.uark.edu Fayetteville, AR 72701
Voice: (501) 575-6159 FAX : (501) 575-3846
