Is the Grass ver 4.1 suitable for...
Hi All,
I'm new subscriber to the GRASSU list, so, please do correct me if I'll
do anything wrong. My problem is as follows, I've several air photos scaned
with 150 dpi resolution, each 1240 x 1240 points, which I'd like to join
together using geometrical correction if necessary. Some of my photos are
of slightly worse quality, and with some an overlap is rather large. I wonder
whether the Grass ver 4.1 might be suitable for the problem at hand?
An Oldak
Yes, Grass4.1 will do what you want: interactively rectify your photos with
a precision that you determine yourself, adjust resolution and greyscale
histograms to whatever you wish, cut and paste photos together.
Martijn van Leusen
