Folks,
I'm looking for the simplest way (in GRASS) to solve a problem of
the following sort:
Given a layer of townships (polygons), and a layer of roads (vectors),
compute the length of road in a given township.
I started out converting the polygons to raster regions and producing
a mask, and then converting the roads to raster and running r.report.
But this generates areas or cell counts, which are at best a crude way
to measure lengths.
It seems that vector displays are unaffected by masks, and I also cannot
find any tool to compute the length of vectors in a vector file. If I
could mask the vector file and then run something like a "v.report" I
think I'd have it. SO:
a) Is there a way to mask vector files?
b) Does someone have something like a "v.report"?
(I found v.area, which must do the same calculation to get
the perimeter values it reports).
Thanks! Steve Frysinger
