Island software
Erin,
This has been asked before but no problem.
I've imported ps.map output into IslandDraw, modified/added text or vectors
and printed to an HP Phaser II postscript printer. I've not attempted to
modify the raster layer from within IslandDraw/IslandPaint other than
resizing. From what I've been told, you can get a demo version to
test IslandDraw's capabilities.
If you are running NeXTStep, "Tailor" is another postscript editing
program that is worth looking into.
Wayne Gibson
Oregon State University
I hope this has not been asked before, because apparently repetition
is fuel for flames. Has anyone had luck importing ps.map output into
Island Paint (of Island Write, Draw & Paint)? I sure don't want to
spend 1K bucks if it doesn't, but I'm tired of not having Postscript
capabilities. I'm hoping I'll be able to make good maps on my HP
Paintjet XL. The literature says has conversion capabilities for
PostScript and HPGL.
Erin O'Doherty
Rocky Mtn Exp Station
USDA Forest Service
Laramie WY USA
In article <9410252026.AA03421@chaos.ats.orst.edu>,
oregon@chaos.ATS.ORST.EDU (George Taylor) writes:
I use IslandDraw quite a bit for this purpose also. George: one question --
when I import a ps.map generated eps object into IslandDraw, it always has a
box (the Postscript bounding box?) around it. Do you know of a way to get
rid of the box (using either ps.map or IslandDraw)?
Bob Harrington
