IVL GPS + GRASS
Since my last request for help was a bit vague, I'll expand a bit..
I intend to implement an Intelegent Vehicle Location (IVL) system.
Basically, multiple mobile gps units will talk to the base station
(a PC running Linux/GRASS?). The PC will take information from
an RF radio through its serial port. This information will include
the position of each mobile unit, the satellites each mobile unit
is tracking, etc, etc and make the info available on the PC with
a map of the surrounding area. As far as GRASS goes, all I need
it for is to display the map on the PC screen using DXF or Tiger files
and take the information from the serial port and display dots on
the screen indicating each of the mobile units.
Now that I have given a little more info, what pieces of GRASS (v.digit+?)
should I look at first? GRASS is a large package and somewhat
intimidating... I just need to be pointed in the right direction
to begin...
thanx in advance for the info,
-jr-
J.R. Spidell (jspidell@cl08.cnde.iastate.edu ) writes on 10 May 94:
to begin...
d.vect (to display DXF or Tiger files)
d.points
You may have to do a bit of coding, depending upon what get's fed into
the serial port. Say, for example, we have data in the form
"Vehicle# easting northing." Then, you may want to do something like:
while(data is coming in)
  switch(vehicle)
    case CAR : /* car is green */
  sprintf (buf, "echo %g %g | d.points c=green s=1 t=+\n", east,north);
        G_system(buf);
  break;
    case TRUCK : /* truck is red */
  sprintf (buf, "echo %g %g | d.points c=red s=1 t=+\n", east,north);
        G_system(buf);
  break;
    default :
    break;
Alternatively, you may look at popen() (depending upon how often
a mobile unit sends a signal, popen may be much more efficient).
  process=popen("d.points", "w");
  fprintf(process,"%g %g\n",east,north);
Don't let the C code be daunting (if you're not a programmer). What
you are asking about seems fairly straightforward (and could possibly
be done without C programming). If you run into problems, ask the good
folks on grassp-list.
Assuming that you have already imported your Tiger or DXF files,
you first need to find out what the format of the data coming in
from the serial line looks like. Then, it's just a matter of
parsing it and feeding it into d.points.
Good luck,
-jr-
--Darrell
James Darrell McCauley, Purdue Univ, West Lafayette, IN 47907-1146, USA
mccauley@ecn.purdue.edu, mccauley%ecn@purccvm.bitnet, pur-ee!mccauley
** will finish PhD/engr in 9/94 - need job. inquiries welcome (no hh, plz) **
** Personal WWW page URL ftp://pasture.ecn.purdue.edu/pub/mccauley/me.html **
