lat-lon vector data with v.in.ascii/v.support
Dear grasshoppers:
  I have a question regarding using v.in.ascii and then v.support for lat-lon
vector data. I found that v.support refused to attach category to an area (A) or
polygon, although the point (in lat-lon) is inside the region, however:
PNT_TO_AREA failed: (30.022011, -95.697998) (Category 502)
these message streamed out.
  Is there a fix for this or am I using the tools wrong ? My input data is
GRASS vector format <header> A <n-points> <points> A<n-points> <points> etc..
and an attribute file is created for each polygon (also a label file).
The import works fine, ie. i can display with d.vect but attaching attribute
is impossible.
Any help is appreciated. Thanx
cheers
duc@comsearch.com
Duc Nygen (duc@comsearch.com) writes on 28 Jan 93:
you may want to run v.digit (with the grass monitor) and ask
it to show which areas are not closed. (it's under Toolbox;
"o - Display Open area lines"). If you find an open area,
remember the general location, convert your cats/atts file
to a site list, and run 'd.erase; d.vect file1; d.sites file2'
If a site lies in this open area, then the PNT_TO_AREA failure
should be expected.
Now, how should you fix this? You might try running v.support
with some snap. A run with v.spag might not hurt.
huh? you only need one attribute file and one cat file per binary
vector file. Do you only have one polygon per vector file?
is impossible.
cheers
duc@comsearch.com
