I'am trying to convert data from lat/long format to UTM
I seem to get different results depending on the conversion program I use and
the format that the lat/long is provided.
Joe - I found that if you use decimal degrees, then you have to use +/-
notation to indicate N/S or E/W. I notified CERL so that they could either
fix it or update the manual. I don't know which path they chose. Try that
fix, anyway, and see if it makes things more consistent. Alternatively,
you might like to use Gerry Evenden's PROJ program, which is available from
charon.er.usgs.gov:/pub/PROJ.4 (128.128.40.24)
(I will be installing this at DEM Nedlands as soon as they give me some disk!)
Simon Cox
____
__________________________________________________________________
Dr Simon Cox __ L
CSIRO Div. Exploration & Mining ,~' L_|\ Australian
39 Fairway, PO Box 437, ,-' \ Geodynamics
Nedlands, WA 6009, Australia ( \ Cooperative
Phone +61 9 389 8421 X ___ / Research
Fax +61 9 389 1906 L,~' "\__/ Centre
s.cox@dem.csiro.au v
