Length of drainage network
Hi GRASS User's:
I have streams map which is an output of r.watershed program. How can I find
the length of drainage network to determine drainage density of the watershed
from this map?
Thanks in advancing for your help
Ezzeddine
e-mail: sdiri@www.maich.gr
from this map?
If drainage density is #stream pixels/watershed, then you can use r.mask
to find stream components in each watershed, and then use r.stats to give
you a cell or area count.
If I'm off in left field, drop me a note.
Angus.
