libc.so gets() warning on FreeBSD
GRASS 4.2 uses gets() function, which is unsafe, many times and
libc.so warns this every gets() call. There are so many garbage output.
You should rebuild standard c library.
Get library sources from FreeBSD archives,
then
        cd /usr/src/lib/libc
        vi stdio/gets.c
                COMMENT OUT THE FOLLOWING LINES:
                        if (!warned) {
                                (void) write(STDERR_FILENO, w, sizeof(w) - 1);
                                warned = 1;
                LIKE THIS:
                        if (!warned) {
                                warned = 1;
                SAVE FILE AND QUIT VI
        make
        vi stdio/gets.c
                UNCOMMENT THE ABOVE LINES LIKE THIS:
                        if (!warned) {
                                warned = 1;
        mkdir /usr/local/grass42/lib
        cd /usr/local/grass42/lib
        cp /usr/obj/usr/src/lib/libc/libc.so.3 .
    IF /usr/obj/.../libc.so.3 DOES NOT EXIST,
            cp /usr/src/lib/libc/libc.so.3 .
        ln -s libc.so.3 libc.so
Now prepend the following line to /usr/local/grass42/bin/grass4.2:
        export LD_LIBRARY_PATH=/usr/local/grass42/lib:$LD_LIBRARY_PATH
Here is my grass4.2:
----<cut here>----
GISBASE=/usr/local/grass42
export GISBASE
exec $GISBASE/etc/GIS.sh
----<cut here>----
If you need FreeBSD 3.3 libc library, this is available from:
        ftp://geni.knu.ac.kr/pub/geni/patch/grass42/libc.so.3
Do not forget 'ln -s libc.so.3 libc.so' and LD_LIBRARY_PATH.
Huidae Cho
Isn't there a library that GRASS uses that you could define a replacement
gets() in that uses fgets() instead? Changing libc seems brutal.
James Cameron mailto:quozl@us.netrek.org http://quozl.netrek.org/
using GRASS 4.x with gets obviously does not cause problems
(beside the compile warnings).
Side note: GRASS 5 does not use gets() but fgets(). It was heavily
upgraded the last month by many contributors.
Best wishes
