libF77.so.1
HELP!!
  I've been fooling around with permissions on my SUN Sparc 10 and
now I can't get GRASS to come up. After the Grass login to which I supply
the MAPSET etc. I get the following message.
ld.so: libF77.so.1: not found
/large/grass4.1/etc/GIS.sh: GISDBASE: parameter null or not set
Anyone of you UNIX GURUS have nay ideas?
Thanx,
Doug Bradley
Southwest GIS Center
Albuquerque, NM
(505) 766-8403
doug@nps.unm.edu
Although I'm mildly surprised that a GRASS 4.1 startup program would be
needing the F77 library, I guess the problem here could have (at least)
two different causes. You might have changed the permissions on your
libF77.so.1 such that it can't be read, or libF77.so.1 might actually be
missing. If it's missing, then it probably used to be a symbolic link to
the latest sub-revision of rev 1 of libF77.so, and somehow that link got
capped.
If it's just the permissions, then I can't imagine the problem not going
away after you correct the permissions so that the library can be read --
then again, I would have thought you'd already tried that. If the problem
is with the symbolic link, you need to reinstate the link so that the
dynamic loader finds a file with the name it's looking for.
If this doesn't help, then I guess I need more information. You can email
me for that.
Oh, yes, the short answer -- Yes, you're right: dynamic loading is
currently "transitional technology", and is not always everything it's
cracked up to be.
Ollaysglatoobeevhelp (to be read with a Gujarati accent).
-- Mark
Mark P. Line Phone: +1-206-733-6040
Open Pathways Fax: +1-206-733-6040
P.O. Box F Email: markline@henson.cc.wwu.edu
Bellingham, WA 98227-0296
