It worked fine for me last night compiling with the last weekly ( 6-18-11) svn snapshot for grass 7.0, I’ll poke it a bit more tomorrow. I’ll need to make some bigger files to test the speed.
Doug
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb@fws.gov
The opinions I express are my own and are not representative of the official policy of the U.S.Fish and Wildlife Service or Dept. of the Interior. Life is too short for undocumented, proprietary data formats.
Howard Butler <hobu.inc@gmail.com> 06/22/2011 12:57 PM |
To |
cc |
Markus Metz <markus.metz.giswork@googlemail.com>, grass-dev@lists.osgeo.org, liblas-devel@lists.osgeo.org |
Subject |
Re: [Liblas-devel] Re: [GRASS-dev] grass7: problem --with-liblas |
Doug,
I think I have this one smashed. <
http://trac.liblas.org/ticket/231> It will be released in libLAS 1.7.0. If you have the ability to pull down a copy of the hg version <
http://hg.liblas.org/main/archive/tip.tar.gz> and test, I'd appreciate it. Also, it should be much, much faster for medium-to-large sized files.
Howard
On Jun 13, 2011, at 11:45 AM, Doug_Newcomb@fws.gov wrote:
> Hi Folks,
> Glynn's suggested hack to liblas-config below to work around the issue in cmake allowed me to compile grass7 with liblas support over the weekend on Ubuntu 11.04 x64. I have not read any las files yet to see if it actaully worked :-) , hopefully tonight I'll get a chance.
> Doug
> Doug Newcomb
> USFWS
> Raleigh, NC
> Sent by: grass-dev-bounces@lists.osgeo.org
> 06/01/2011 03:21 AM
> To
> Glynn Clements <glynn@gclements.plus.com>
> cc
> Martin Landa <landa.martin@gmail.com>, GRASS developers list <liblas-devel@lists.osgeo.org>
> Subject
> On Tue, May 31, 2011 at 11:34 PM, Glynn Clements
> <glynn@gclements.plus.com> wrote:
> > Markus Metz wrote:
> >> Is this "optimized;" and ";debug;" now a problem of GRASS or of libLAS?
> > libLAS. Although it / be an issue with CMake's FindBoost module
> > (search for "optimized" in FindBoost.cmake).
> This seems to be a bug in cmake 2.8.4, not present in cmake 2.8.2. I
> just updated cmake from 2.8.2 to 2.8.4 and now get the same problem.
> Or the syntax in liblas-config.in is wrong.
> I suggest to hack liblas-config and replace the offending line
> LIBS="-L$libdir -llas -llas_c -L/usr/lib
> optimized;/usr/lib/libboost_program_options-mt-1_42.so;debug;/usr/lib/libboost_program_options-mt.so"
> with
> or
> LIBS="-L$libdir -llas -llas_c -L/usr/lib64
> /usr/lib64/libboost_program_options-mt.so"
> >> BTW, what version of libLAS are you using?
> > I'm using the libLAS-1.6.1 source package:
> > $ ls -l libLAS-*
> > -rw-r--r-- 1 glynn root 7817956 May 30 18:49 libLAS-1.6.1.tar.gz
> > $ md5sum libLAS-*
> > 2ce4f36f267c2f25bfc99c3f00e9cbd3 libLAS-1.6.1.tar.gz
> grass-dev mailing list
> ``http://lists.osgeo.org/mailman/listinfo/grass-dev
> Liblas-devel mailing list
> Liblas-devel@lists.osgeo.org
> ``http://lists.osgeo.org/mailman/listinfo/liblas-devel
