Line thickness in ps.map
Steve,
I believe that this is fixed in the newest version of ps.map on the moon
(incoming). You can select a width of 0 in it (I think!). If not, contact
me directly...
Is there anyway to get the line thickness reduced when using the 'ps.map'
command?
I've set the width to 1, but on our Laserjet IV the lines must be > 1mm
thick. The text is fine though, even down to 4 point, so the printer and
Postscript can cope, just that 'ps.map' seems to set lines very thick.
Is this something to do with the screen vs. printer resolution ?
Steve Culshaw
NRA North West
e-mail : nra@cix.compulink.co.uk (general usage)
or sculshaw@cix.compulink.co.uk (Private - only checked at best
weekly)
Malcolm D. Williamson - Research Assistant E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
