lines and areas
Why not grid your contours into a raster, slice them
by elevation and then extract the area of all cells
equal to a given elevation?
--- Malcolm Williamson <malcolm@cast.uark.edu> wrote:
Stefan,
In v.digit, you can re-type lines to area edges. You
can also do this in
bulk by converting to ASCII, using an editor to
change all leading "L"s
to "A"s, and re-importing with v.in.ascii. Either
way, you'll have to
manually attribute all of the areas in v.digit.
Also, I'm really not
sure how robust the GRASS topological model is,
especially concerning
multiple levels of nested areas ("islands").
Best regards,
  -Malcolm Williamson
   CAST - University of Arkansas
> Stefan.Neumann@agrar.uni-giessen.de wrote:
> Hi Grass,
> is there a way to convert lines to areas ? I
create lots of
> contour-lines with r.contour and I would like to
make statistics
> (r.report type=area) on the areas surrounded by
the contour-lines.
> This doesn't work though, because r.contour only
creates lines, not
> areas.
> Also I would like to create a map where the areas
are filled with a
> color according to their attribute (with
v.to.rast). This also only
> seems to work with areas.
> TIA, Stefan
David Finlayson
david_finlayson@yahoo.com
University of Washington
Box 351310
Seattle, WA 98195 - 1310
__________________________________________________
Do You Yahoo!?
Yahoo! Messenger - Talk while you surf! It's FREE.
http://im.yahoo.com/
