Linux Grass Installation
At 02:36 PM 2/4/97 -0700, you wrote:
I have been attempting to install Linux Grass 4.1.5 on an IBM system.
I am using Slackware 96 (version 3.0) and I have not had any luck from
the downloaded files or the files from the CDROM from the book Linux
Configuration and Installation (Volkerding, etc al). The error I am
getting is associated with unexpected end of files, invalid compressed
data, and a failure to read and create files.
I would appreciate any help.
Thanks
Jason Brown
I have installed these binaries successfully. Are you using the binaries
that start with linux.. and Kang's install script (install.sh)?
Jim Schmidt
avenues@sonnet.com
Melissa and Ungar
avenues@sonnet.com
From - Tue Jul 08 13:18:33 1997
From owner-grassu@isis.cecer.army.mil Sun Jul 6 17:12:33 1997
Received: from isis.cecer.army.mil (isis.cecer.army.mil [129.229.101.1]) by mail.uni-muenster.de (8.7.5/8.7.5) with ESMTP id TAA62664 for <eicksch@uni-muenster.de>; Sun, 6 Jul 1997 19:12:31 +0200
Received: (from listserv@localhost)
  by isis.cecer.army.mil (8.8.5/8.8.5) id JAA22819
  for grassu-outgoing; Sun, 6 Jul 1997 09:54:11 -0500 (CDT)
X-Authentication-Warning: isis.cecer.army.mil: listserv set sender to grassu using -f
Received: from pandora.cecer.army.mil (pandora.cecer.army.mil [129.229.103.1])
  by isis.cecer.army.mil (8.8.5/8.8.5) with ESMTP id JAA22809
  for <grassu@cecer.army.mil>; Sun, 6 Jul 1997 09:54:05 -0500 (CDT)
Received: from tabajara.iag.usp.br. (tabajara.iag.usp.br [143.107.14.50])
          by pandora.cecer.army.mil (8.8.5/8.8.4) with ESMTP
    id JAA02270 for <grassu@cecer.army.mil>; Sun, 6 Jul 1997 09:54:01 -0500 (CDT)
Received: from adalbert.geofisica.iag.usp.br (tty7.squid.uspnet.usp.br [200.17.23.17]) by tabajara.iag.usp.br. (8.7.6/8.7.6) with SMTP id MAA25741 for <grassu@cecer.army.mil>; Sun, 6 Jul 1997 12:00:45 -0300 (EST)
Message-ID: <32F9ED8D.1A96@iag.usp.br>
Date: Thu, 06 Feb 1997 11:41:17 -0300
Organization: Instituto Astronomico e Geofisico -USP
X-Mailer: Mozilla 3.01Gold (Win95; I)
MIME-Version: 1.0
To: grassu@cecer.army.mil
Subject: Floating point exception
References: <199707041621.KAA18008@ulysses.sis.ualberta.ca>
Content-Type: text/plain; charset=us-ascii
Content-Transfer-Encoding: 7bit
Sender: grassu@pandora.cecer.army.mil
Precedence: bulk
Reply-To: grassu@cecer.army.mil
X-Mozilla-Status: 0001
Status: O
Content-Length: 752
Lines: 24
Hello,
  I'm trying to run s.surf.tps under Linux. I'm using Andreas Holz's
compilation.
  When I run s.surf.tps and fill in with requested information (in this
case a site file with 150 thousand records extracted from a digitized
topographic map and the default parameters) I get the message:
  >Floating point exception (core dumped)
  Using s.surf.idw it seems to work but as fast as a snail (I aborted
operation when it had calculated about 50 ou of 6,000 lines! And my
Linux box is a Pentium 133 with 64 Megs...
  I read some messages concerning the same issue apparently under Solaris
but I don't know what can apply to my problem.
  Adalberto da Silva
  Instituto Astronomico e Geofisico - USP
  Sao Paulo - Brazil
  adalbert@iag.usp.br
From owner-grassu@isis.cecer.army.mil Sun Jul 6 17:24:17 1997
Received: from isis.cecer.army.mil (isis.cecer.army.mil [129.229.101.1]) by mail.uni-muenster.de (8.7.5/8.7.5) with ESMTP id TAA41766 for <eicksch@uni-muenster.de>; Sun, 6 Jul 1997 19:24:15 +0200
  by isis.cecer.army.mil (8.8.5/8.8.5) id KAA23129
  for grassu-outgoing; Sun, 6 Jul 1997 10:06:55 -0500 (CDT)
  by isis.cecer.army.mil (8.8.5/8.8.5) with ESMTP id KAA23119
  for <grassu@cecer.army.mil>; Sun, 6 Jul 1997 10:06:50 -0500 (CDT)
    id KAA02291 for <grassu@cecer.army.mil>; Sun, 6 Jul 1997 10:06:49 -0500 (CDT)
Received: from adalbert.geofisica.iag.usp.br (tty7.squid.uspnet.usp.br [200.17.23.17]) by tabajara.iag.usp.br. (8.7.6/8.7.6) with SMTP id MAA25820 for <grassu@cecer.army.mil>; Sun, 6 Jul 1997 12:13:34 -0300 (EST)
Message-ID: <32F9F08E.EF3@iag.usp.br>
Date: Thu, 06 Feb 1997 11:54:06 -0300
MIME-Version: 1.0
Subject: Keyboard doesn't work with Xgrass
Precedence: bulk
Status: O
Content-Length: 1433
Lines: 34
Hello,
  Is there anybody using A. Holz's Xgrass compilation that could help me?
  By running Xgrass with 'xgrass4.1 &' my console is flooded with
messages like:
Warning: translation table syntax error: Unknown keysym name: osfActivate
Warning: ... found while parsing '<Key>osfActivate:ManagerParentActivate()'
Warning: translation table syntax error: Unknown keysym name: osfCancel
Warning: ... found while parsing '<Key>osfCancel:ManagerParentCancel()'
Warning: translation table syntax error: Unknown keysym name: osfSelect
Warning: ... found while parsing '<Key>osfSelect:ManagerGadgetSelect()'
Warning: translation table syntax error: Unknown keysym name: osfHelp
Warning: ... found while parsing '<Key>osfHelp:ManagerGadgetHelp()'
Warning: translation table syntax error: Unknown keysym name: osfBeginLine
Warning: ... found while parsing '<Key>osfBeginLine:ManagerGadgetTraverseHome()'
Warning: translation table syntax error: Unknown keysym name: osfUp
Warning: ... found while parsing '<Key>osfUp:ManagerGadgetTraverseUp()'
  (this is only a sample as long as the messages I captured in a log file
has some 20 kbytes somewhat identical)
  When I click to 'Add Items' I can't fill any box as long as the
keyboard doesn't work! But it does in the Grass shell.
  Is there any suggestion?
  Adalberto da Silva
  Instituto Astronomicoe Geofisico - USP
  Sao Paulo - Brazil
  adalbert@iag.usp.br
