1) I need the linux binary for v.extract. If you could uuencode this and
mail it to me I'd be most grateful.
2) I am loading some USGS dlg's into v.digit to manually edit them, then I
save them, v.clean them, and v.support them. I end up with some lines that
were one segemnt from node to node (the neatlines) being fragmented into
having (seemingly) random nodes pushed into the middle of the lines. Am I
doing something wrong?
3) When I v.import DLG's, how do I make it keep the full att code? I end up
with att codes like "402" instead of "190-402" and the like.
Thanks...
Ry
rjones@halcyon.com net.viking 507915.21E 5209567.01N UTM ZONE 10 OG+GOT;
GCS/S/O: d? H--- s+:+ g+ p1+ au-- a- w+++ v++ C++++ UL++++ P+ L++ 3- E---
N+
K++ W++ M-- V-- -po+ Y++ t !5 jx R G''' tv+ b+++ D++ B--- e+ u*--- h---- f
r+++ !n---- y++++ GeekCode v2.1 available: finger hayden@vax1.mankato.msus.edu
