LL coordinate system
I want to convert a scanned map (x,y coordinate system) into latitud/longitude
coordinate system. With the i.points (i.rectify,...) command I can convert
my map into the UTM coordinate system or the State Plane coordinate system
but not into latitud/longitude coordinate system.
Does anyone know how I could do this?.
Thanks in advance.
Anabel Donadios
Eurogis
In info.grass.user you write:
Thanks in advance.
Anabel Donadios
Eurogis
To convert a vector map from one projection to the other use v.proj
To convert (x,y) from one projection to another use m.proj (it has an
options to read coordinates from file).
Irina
Irina Kosinovsky [irina@zorro.cecer.army.mil]
Construction Engineering Research Labs, US Army Corps of Engineers
Champaign, Illinois (217)352-6511 x676
Error 13: Illegal brain function. Process terminated.
REALITY.DAT not found. Atempting to restore Universe.
REALITY.SYS Corrupted - Unable to recover Universe
Press any key to quit, or any other key to continue...
