Hi Venkatesh!
Thank you - you are very right!
Hi Markus,
Please correct me if I am wrong.Markus Neteler wrote:
> libc.so.5 based systems are: Redhat 4.x, SuSe 5.x, COL 1.3 (Caldera)
> -> go for GRASS 4.2.1 (V.21) or newer distributionsThat should read GRASS 4.2.1 (V.20), isn't it?
Yes! To bad, this copy/paste function without auto-correction.
> Or you compile the source code yourself, then you avoid the
> problem.
>If one is compiling from source on libc.so.5 based systems the
CURSES = -lncurses $(TERMLIB)
line in the "../src421/src/CMD/head/linux" file also needs to
be edited as below;CURSES = -lcurses $(TERMLIB)
since libc.so.5 based systems normally curses instead of ncurses.
I just compiled from the source file but needed to make the above
change on my libc.so.5 based system.Venkatesh Raghavan
On my former SuSe5.3 Linux I had to use a special version of libcurses.
The preinstalled libcurses caused problems. People having this problem
can get this special libcurses library from GRASS 4.2.1 FAQ page.
I expect that all this library confusion shall disappear soon when
all people have upgraded their Linux.
I hope the GRASS installation pages for Linux are more clearly now
concerning libc.so.5 and libc.so.6. Perhaps I can get some feedback?
All suggestions are welcome!
Markus Neteler
