locking mechanism on monitor
In message <33258B81.1E4D@tiaer.tarleton.edu> writes:
Help. I was working in grass and went to display a raster map and my
monitor would not respond giving me the following message:
locking mechanism failed
lock file <where located>.
That lock file was empty. I rebooted my computer and still no response
from x0 monitor. What happened ??? I can bring up another monitor x1
but my x0 will not respond.
GRASS creates a file as a locking mechinism. If the file exists, it indicates
that the resource (monitor in this case) is in use and cannot be accessed. When
you release the monitor using d.mon, the file should be deleted.
Is there a way to fix this problem. Thanks for your help .
Yes, delete the file. If you don't have permission to delete the file, ask your
system administrator to delete it for you.
That should solve the problem.
Michael Hanratty Phone: (612) 627-4590
St. Anthony Falls Laboratory Fax: (612) 627-4609
Dept. of Civil Engineering
University of Minnesota
Mississippi River @ 3rd Ave. SE
Minneapolis, MN 55414
