EVERYTHING in an expression is evaluated, even all the arguments
to an if(). (The reason is that if() isn't a logic operaion but a
function that happens to be named if and happens to behave the
way it is described in the manual). You have stumbled onto a bug
in r.mapcalc. The bug is log(0) or exp(0,x) should detect the
zero and not call log() and exp() but set the result to NODATA
(which is 0). If the floating point exeception messages don't
actually abort r.mapcalc, see if the result map has zeros where
there are zeros in the imput (ie, see if r.mapcalc does the right
thing).
The floating-point exception messages I hope will be benign in
this regard. However, I will report this as a bug in r.mapcalc.
|Hi
|In an attempt to overcome a domain error problem encountered while using r.mapcalc's exp(x,y) function I tried to use the log and exp functions together.
| r.mapcalc 'file=if(file.??,log(file.??)'
|When I use these funtions I get the message that an overflow has occured during the calculations. I have used an if statement to protect the log from the zero's in the data file and the rest of the data is well within the acceptable range. The values obta|ined are correct and no strange occurances exist.
|In trying to track this down I converted all the zero values to 1 and ran the routine again. No overflow occured. It appears that the presence of the 0 data is not being dealt with by the if statement.
|Does anyone have an insight into how r.mapcalc is operating in this reguard?
|Steve
|Steve Huddle, Graduate Student
|School of Engineering, University of Guelph, Guelph, ON, Canada, N1G 2W1
|E-Mail InterNet: HUDDLE@Net2.EOS.UoGuelph.Ca
|Telephone: (519) 824-4120 ext 4323 FAX: (519) 836-0227
Michael Shapiro U.S. Army CERL
email: shapiro@zorro.cecer.army.mil Environmental Division
phone: (217) 373-7277 P.O. Box 9005
fax: (217) 373-7222 Champaign, Ill. 61826-9005
