LTPlus import ?
Just a followup to my LTPlus import question,
Thankyou Ronalds Wiemer, your answer was most helpful.
I would like to state the process we are taking to import scan images
into LTPlus.
1. scan image into a PCX file format (we can't scan directly to sunrast).
   note: that on our scanner you have to make sure that the # of column pixels
         is even. We are imp
rting into grass using r.in.sunrast,
         r.in.sunrast seems to have a problem with odd # of columns.
         We are running grass 4.1.
2. convert PCX file to SUNRAST using PBMplus utilies.
     anytopnm filename.PCX | pnmtorast -standard > filename.RAS
3. import into grass
     r.in.sunrast
4. export as a ascii file (make sure you reset your g.region)
     r.out.ascii map=yourmap -h | tr -d " " > filename
5. import into LTPlus in rstr format, bitmask = 1, no of lines per scanline = 1
if any of you LTPLUSers have a method with less steps, let me know.
again thankyou Ronalds Wiemer.
I'm trying to import a image from our HP ScanJet IIc in to LTPlus.
I can output in a lot of formats, but it looks like RLE (Run Length Encoded)
is the only compatable format. LTPlus reads this file just fine, but
the resulting image is garbage. Why is this? What am I doing wrong?
What formats are you LTPlus(ers) using to import Scan images?
About two weeks ago I had the same problem. I found out that you can
use simple ascii, the following way:
Import your scanfile in grass, using ppm e.g. export the grass
rasterfile with:
It is a rather complex way to do this but it works. Beware that you have to
scan in linemode, so there will only be zeros and ones in your scanfile.
Ronalds Wiemer
ARCHIS, Amersfoort, The Netherlands
William J. Dailey, GPSR Systems Analyst
USDA-ARS-NPA
Great Plains Systems Res. TEL: 303-490-8324
P.O. Box E FAX: 303-490-8310
303 South Howes Rm. 227 FTS2000: A03RLGPSR
Fort Collins, CO 80522 INTERNET: dailey@gpsrv1.gpsr.colostate.edu
Hi LTPlus users,
I have found a simpler method for importing images in LTPlus. I have made
a program called pnmtoltp, it is a modification of pnmnoraw, the only
difference is that pnmtoltp does not write the ppm header to the top of
the file. You could also strip the header off using the unix cmd tail.
Since pnmnoraw writes lines of 70 characters, you will have to calculate
the number lines per scanline as follows: (#columns / 70) + 1.
This way, importing in GRASS is no longer necessary.
Ronald Wiemer
ARCHIS, Amersfoort
The Netherlands
