m.clump (was Re: [GRASS5] Misc. Module Errors)
On Tuesday, December 5, 2000, at 11:20 PM, Eric G . Miller wrote:
> Both "src/mapdev/v.geom/cmd" and "src/misc/m.clump" get this error:
> /usr/bin/ld: Undefined symbols:
> _GLOBAL_INTERRUPT_ALGORITHM
> _gcvt
> GISGEN failure at STEP: src/mapdev/v.geom
Well, I think this command must be moved out of default build anyway
(license problem).
m.clump now reports the following error:
cc: /usr/src/grass/src/libes/LIB.powerpc-apple-darwin1.2/liboptri.a: No such file or directory
cc: /usr/src/grass/src/libes/LIB.powerpc-apple-darwin1.2/libsos.a: No such file or directory
cc: /usr/src/grass/src/libes/LIB.powerpc-apple-darwin1.2/liblia.a: No such file or directory
cc: /usr/src/grass/src/libes/LIB.powerpc-apple-darwin1.2/libbasic.a: No such file or directory
make: *** [/usr/local/grass5/etc/bin/main/cmd/m.clump] Error 1
Any ideas?
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
subject 'unsubscribe grass5'
On Sun, Dec 10, 2000 at 06:10:38PM -0800, Jeshua Lacock wrote:
Any ideas?
The libraries in question had to be [re]moved because there is no public
license to use them. Consider m.clump removed for the time being as
well. (See posts about detri replacement ...)
Eric G. Miller <egm2@jps.net>
> > _gcvt
> (license problem).
m.clump is moved to /unused/misc/ now due to the dependency on
copyright restricted geom lib.
Like this the compile problem "goes away"...
(shall I upload the new detri lib?)
