I am a grass user trying to extract a DEM from a tape drive. I have not
been very successful. Each time i try to extract the DEM i get the message
m.rot90:disc quota exceeded. I checked my disc space there is no problem there
the problem is some where in the execution of the command
m.dem.extract input=' " output=" " blocksize=" ".
can some one solve my problem. I am attaching the error message as i read
it on the computer.
min elevation: 0.000000 max elevation: 0.000000
ns_res: 0.000000 ew_res: 0.000000
# of columns in file = 0
Making system call to m.rot90m.rot90 input=/ecn/kittyhawk/rent0/sktangel/macalester.w/practice/.tmp/
skywarrior.ecn.uoknor.edu/15263.0
output=/ecn/kittyhawk/rent0/sktangel/macalester.w/practice/.tmp/
skywarrior.ecn.uoknor.edu/15263.1 bpc=4 rows=1292400 cols=360
m.rot90: error writing output file: Disc quota exceeded
ERROR: can't rotate cell file
I am not sure exactly what you are doing, but did you really have a dem file
with 1,292,400 rows and only 360 columns? Can you be more specific about what
you told the machine in the m.dem.extract command? Did you actually leave the
input, output, and blocksize blank? You need to specify them based on the file
on the tape. example:
m.dem.extract input=/dev/rmt0 output=elev.quad blocksize=4096
m.dem.extract has historically had problems with tape format variations,
specific devices, etc. but can work great. As far as I know, it currently
only extracts 7.5 minute DEM data (1:24000 scale) NOT 1:250000 scale. If
your data are the 1:250000 scale data, you need to dd the file and pipe it
into m.dmaUSGSread, then run m.rot90, and r.in.ll. See GRASS 4.0 Tutorial:
DTED and DEM Elevation Data Extraction by Stuart Bradshaw, Mary Martin,
Chester Kos, and Scott Tweddale, December 1991.
Good luck and have fun!
Susan Stitt
National Park Service
Geographic Information Systems Division
PO Box 25287 12795 W. Alameda Parkway
Denver Colorado 80225-0287 Lakewood Colorado 80228
(303) 969-2596
susan%nps@cerl.cecer.army.mil
