Jeri, Matt and others,
I recently had problems and questions about importing 1deg DEMs
(from edcftp.cr.usgs.gov/pub/data/DEM/250) and received the helpful
message below. Also very helpful for learning about DEMs and what
the numbers in the header mean I suggest you look at the info via
Mosaic http://edcwww.cr.usgs.gov/glis/hyper/guide/1_dgr_DEM
( if you dont have access to Mosaic I can send you an eddited copy).
Also, get a copy of USGS booklet "Digital Elevation Models, Data
Users Guide"
---begin included message---
The following is a set of general instructions and a specific example
of the commands used to import 1 degree by 1 degress dem data:
EXAMPLE INSTRUCTIONS:
1) dd if=diskfilename ibs=10240 | \
m.dmaUSGSread top=1 bottom=400 left=1 right=500 \
output=dem logfile=log
Of course you need to substitute the right parmaters to describe
the portion of the 1 degree by 1 degree area which you wish to
extract; in this example the first 500 columns of the first 400 rows of
data. These two paramater remain the same for steps 2 and 3. The
blocking paramater (ibs) should NOT be changed, regardless of area
quad, etc.
2) m.rot90 input=dem output=dem.r90
rows=400 cols=500 bpc=2
3) Create a region (in UTM coordinates) with g.region, then
r.in.ll input=dem.r90 output=dem.utm
dimension=500,400 bpc=2 res=3,3
corner=sw,37:13N,103:45W spheroid=wgs72
in the last command you have to give lat-long for a corner of your
dem using the wgs72 spheroid. The r.in.ll command should create all
the necessary support files for you. But if you run into problems, just
run r.support.
SAMPLE SESSION:
[Note: Unlike the above instructions, in the following session I loaded
the entire 1 degree by 1 degree area, i.e., 1201 rows by 1201 cols of
data.]
Mapset <dem> in Location <whatever>
GRASS 4.0.2 > dd if=tulsa_w.dem ibs=10240 | m.dmaUSGSread top=1
bottom=1201 left=1 right=1201 output=tulsa_w.out logfile=tulsa_w.log
The requested window is:
rows: 1-1201, cols 1-1201
863+1 records in
17261+1 records out
GRASS 4.0.2 > m.rot90 input=tulsa_w.out output=tulsa_w.rot90
rows=1201 cols=1201 bpc=2
1,1
1,101
1,201
1,301
