Major problem trying to install 5.0beta3 for linux
Subject: Re: Major problem trying to install 5.0beta3 for linux
On Wed, 22 Sep 1999, Ben Horner-Johnson wrote:
I know this is a little late, but wouldn't it have been better to do
'rm -rf bin' from /usr3 or 'rm -rf /usr3/bin'.
'rm -rf /bin' to me means "go to the root partition (/) and then remove the bin
directory" - which is what happened.
  I was in /usr3 and I did type rm -r bin/ (messed up in the message).
Somehow, the directories are appearing in two places.
Ah.
  Regardless of how I screwed up, untarring the tarball should not have made
bin, dev, etc and so on appear as directories under /usr3. _That's_ what got
me in trouble in the first place.
  After almost 30 hours, the backup is 98% complete. When it's done I'll go
the route of restoring the /bin directory. Then I'll change out the hardware
and clean up the messy GRASS install.
  Wonder why it did this to me when no one else reported spurious
directories during installation.
  Sigh.
I also thought there was an install script (grass5install.sh) available in
the same directory as the binary tar.gz file
  Not that I saw. In the /binary directory there was only the tarball. Once
I untarred it grass5install.sh was in the /usr3 directory.
Hmm... I remembered seeing something about the install script and did some
checking. It's on the German mirror site. The binary directory has subdirs
for different platforms, each linux subdir has grass5install.sh as a separate
file along with the tarball and COPYRIGHT, LICENCE, WHATS_NEW, and REQUIREMENTS
html files.
  http://www.geog.uni-hannover.de/grass/grass5/binary/
I didn't see grass5.0beta3 on the keck ftp site, but I didn't look too hard.
Ben Horner-Johnson
ben@earth.nwu.edu
REQUIREMENTS
html files.
The grass5install.sh I downloaded from the German mirror was giving an
unexpedted EOF at line 124. So I copied the grass5install.sh from a
previous tarball (I had also downloaded from Keck and therefore did not see
the grass5install.sh and had gzip -d'ed it). Once I ran the new
grass5install.sh on the .gz file I had no prolbems installing it on a
RedHat 6.0 box except that this install script was expecting a
/usr/local/grass-5.0b directory and I was using a /usr/local/grass5. So I
just changed my directory name to grass-5.0b and after the successful
install changed the directory name back to grass5. Hats off to you folks,
nice job.
My only bug observation is the same one I noted in the original 5.0beta
release. s.menu reporting functions are garbled and unreadable (i.e. site
characteristics, site reports). Is anyone else having this problem? I
have run into this on both a powerPC and a AMDK6-2 running Redhat versions
of Linux.
Grass aricle in Linux Journal
http://www2.linuxjournal.com/cgi-bin/frames.pl/lj-issues/issue63/2983.html
R. Joe Brandon
1-614-847-1202
http://www.cast.uark.edu/~rjoe
mailto:rjoe_brandon@iname.com
