Ronald:
Attached is an explanation of a code fix that will help
with the name-too-long problem with make.legend in the
GRASS-MAPGEN Interface.
Scott Wade wade@zorro.cecer.army.mil
U. S. Army Construction Engineering Research Laboratories
Env. Compliance Division, Spatial Analysis & Systems Team
Champaign, Illinois
This correction will help solve one of the problems encountered
by folks using the GRASSMAPGEN Interface. They will be trying to
create an ordinary legend, and it fails for now apparent reason.
That is because the name they use for "tmp" is too long. The 15
character limit is too short. That is why it needs to be changed to 50.
The fix:
* For make.legend program,
edit src.related/mapgen/SCS/make.legend/make_leg.c file:
expand the character arrays pfile, tmp, and outfil
from 50, 15, 50 to 100, 50, 100 respectively:
char c, *s, *p, *tp, line[120], pfile[50], tmp[15], outfil[50];
Then recompile.
