making slides
GRASS users--
Has anyone succeeded in making slides directly from GRASS images, as
opposed to photographing the screen? If so, how did you do it?
We have the `xv' software installed, which grabs the screen or a GRASS-
generated ppm file and writes PostScript files in the 24x35mm format.
The resultant file is sent to a remote queue attached to a SlideWriter.
Martijn van Leusen
U of Amsterdam
BTW: Photographing the screen - if you take care to avoid distortion -
  can result in very nice slides too.
- > can result in very nice slides too.
I have taken slides of the screen with excellent results in the past,
several hints:
1) Use a totally dark room - this decreases glare and increases contrast.
2) Use a telephoto (or zoom) lens - this dimminishes the distortion of the
curved screen
3) Try to zoom in as much as possible to get only the screen - don't
purposefully include the monitor frame (the plastic edge around the glass).
It is not possible to get a picture without some of the frame included but
since you are in a dark room it shouldn't appear on the slides.
Good luck,
Pat McClanahan Internet:mcclanah@dlgeo.cr.usgs.gov
EROS Data Center mcclanah@edcserver1.cr.usgs.gov
Sioux Falls, SD
605-361-4607
