> GRASS users--
> Has anyone succeeded in making slides directly from GRASS images, as
> opposed to photographing the screen? If so, how did you do it?
We have the `xv' software installed, which grabs the screen or a GRASS-
generated ppm file and writes PostScript files in the 24x35mm format.
The resultant file is sent to a remote queue attached to a SlideWriter.
XV also has its own TIFF output option that you might try. Slick program!!
Martijn van Leusen
U of AmsterdamBTW: Photographing the screen - if you take care to avoid distortion -
can result in very nice slides too.
Malcolm D. Williamson - Research Assistant E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
