map projection suitable for Europe
Dear Grass Users
I have a paper map of Europe (including western part of Russia) which I
intend to digitise and use in GRASS. The problem is that I'm not sure what
projection to use in GRASS: the original paper map uses a Lambert Conformal
Conic Projection, and covers a dozen UTM zones. I fear that trying to
force it into a GRASS latitude-longitude projection will cause too much
distortion. I could use Arc/Info (but I'd rather not!).
Many thanks for any help
Roy
Roy Sanderson
Centre for Land Use and Water Resources Research
Porter Building
University of Newcastle
Newcastle upon Tyne
NE1 7RU
United Kingdom
Tel: +44 191 222 7789
Fax: +44 191 222 6563
URL: http://www.cluwrr.ncl.ac.uk
Roy Sanderson wrote:
Dear Grass Users
Roy
Dear Roy,
I had a great wrestle with lambert cc when I worked in France.
You can digitise in Lambert I think As I can save my map in Lambert
The only problem I encounterd and onlu could solve in Arc Info was the
transformatiom from lCC 2 to LCC3 used in France different center line
In my
~/PERMANENT/PROJ_INFO
name: Lambert Conformal Conic
proj: lcc
ellps: clark80
a: 6378249.1449999996
es: 0.0068034812
lat_0: 23.0000000000
lon_0: -96.0000000000
lat_1: 33.0000000000
lat_2: 45.0000000000
~/PERMANENT/DEFAULT_WIND
proj: 0
zone: 0
north: 3199747
south: 3141607
east: 1028750
west: 947210
cols: 4077
rows: 2907
e-w resol: 20
n-s resol: 20
I hope this helps you any further.
As I am not fully sure of my self I did not send the message to the lsit
Best regards
Eric
Name: Eric den Breejen Internet:breejen@fel.tno.nl
Mail: TNO - FEL Addr: TNO Physics & Electronics
       P.O. Box 96864 Laboratory
       NL-2509 JG The Hague Oude Waalsdorperweg 63
Phone: ++31.70.374.0426 NL-2597 AK 's-Gravenhage
       ++31.70.374.0000 Fax: ++31.70.374.0654
