Dear Grass Users,
Is there a simple way of using two map projections simultaneously in GRASS?
I have a GRASS location in UTM, but need to add new maps by digitising
from base maps stored as latitude-longitude. The v.digit command only
seems able to cope with digitising using the same projection as the
original location (in this case UTM). I could resort to using Arc/Info for
digitising, then PROJECT/TRANSFORM into UTM before exporting to GRASS, but
I'd prefer to carry out the whole operation in GRASS if possible.
Roy
Roy Sanderson
Centre for Land Use and Water Resources Research
Porter Building
University of Newcastle
Newcastle upon Tyne
NE1 7RU
United Kingdom
Tel: +44 191 222 7789
Fax: +44 191 222 6563
URL: http://www.cluwrr.ncl.ac.uk
Hi, Roy
Create a new lat-long Location, and digitize your maps in that Location.
Use v.proj to re-project the lat-long maps to UTM in your other Location.
Hint: both Location should be under the same directory (GRASS
"Database"), though you can always resort to symbolic links if you don't
have enough physical disk space. Happy digitizing,
Malcolm D. Williamson - GIS Specialist E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
On Fri, 13 Jun 1997,
R.A.Sanderson wrote:
Dear Grass Users,
Roy
Roy Sanderson
Porter Building
Newcastle upon Tyne
NE1 7RU
United Kingdom
No-- A location has to contain the same projections, as I understand it.
However, I had good success using r.resample on a ll projection in a ll
location, that covered three UTM zones. I g.copy the file to a temp
mapset. Then with unix commands I moved 'mv' the temp mapset to the UTM
location. Then restarted grass in the UTM location and modified the
cellhd/file into utm coordinates using m.ll2u.
Jason Carey
Snow Hydrology
University of Utah
On Fri, 13 Jun 1997, R.A.Sanderson wrote:
Dear Grass Users,
Roy
Roy Sanderson
Porter Building
Newcastle upon Tyne
NE1 7RU
United Kingdom
