Date: Tue, 1 Jun 93 13:39:36 EDT
Message-Id: <9306011739.AA22954@charon.er.usgs.gov>
Sender: lists-owner@max.cecer.army.mil
Reply-To: grassu-list@max.cecer.army.mil
Precedence: Bulk
Subject: Re: MAPGEN and GRASS>From grass-lists-owner@max.cecer.army.mil Mon May 31 22:08:15 1993
>From: Andrew Hertz <hertz@geog.psu.edu>
>Subject: MAPGEN and GRASS
>Date: Mon, 31 May 1993 21:36:03 -0400
>Hi,
>I have several MAPGEN/GRASS questions...
>I just downloaded and installed GRASS4.1 and I noticed that
>the mapgen and proj versions embedded within GRASS don't
>seem to match the most up to date stuff on charon.er.usgs.gov.
>GRASS seems to be using mapgen version 4.0 and proj versions 3.1, 4.5, and 4.6. On charon... is mapgen version 4.1 and proj
>version 4.1.3. Do you suggest getting the latest from charon
>and using it in src.related.mapgen? And can you explain the
>three versions of proj in GRASS and what versions 4.5 and 4.6
>correspond to?The GRASS release is a snapshot of what is current at the time when
CERL makes up its release. MAPGEN, consisting of the basic mapgen
directory and graphics subsystem, has been fairly static, so the GRASS
release should be fairly close to charon's.Proj, however, has been quite dynamic since the release of 4.x and thus
CERL's release quickly goes out of date. I expect release 4.2 to come
out late this summer and will, among other updates, include datum
translation procedures.One other element that confuses charon vs. GRASS, is that charon's
PROJ.4 is designed to be as ANSI (and now ISO, when I get some docs
on this) as possible. Because of CERL's current commitment to K&R
code, they translate PROJ.4.
MAPGEN and PROJ that are distributed with GRASS were installed by the
SCS with their value added GRASS-MAPGEN interface. The versions
of MAPGEN and PROJ have not been updated for fear of breaking the
GRASS-MAPGEN interface. So what is there is the same that was
released with GRASS 4.0.
As for ANSI vs. K&R, on a completely separate track, we used the proj
library with some code that SCS contributed, and have provided integrated
projection support within GRASS 4.1. To do that, we had to take
the latest version of the proj library (well it was latest a few months back)
and convert it to K&R and installed it as a library in GRASS. This
copy of the library has nothing to do with the GRASS-MAPGEN interface.
David Gerdes
US Army Construction Engineering Research Lab
Spatial Analysis & Systems Team
d-gerdes@cecer.army.mil
