mapgen compilation troubles
>I believe the problem is in the make file: that it's trying
>to compile an include file... message follows...
>make: Fatal error: Don't know how to make target `/grass.src/4.1/src.related/mapgen/include/graphics.h'
>Thanks again
>Andrew Hertz
>hertz@geog.psu.edu
Hmm! Seems to me I've heard this problem before.
What is going to have to be done is find the Makefile that is blowing.
Probably in under */mapgen somewhere, depending if you've got release 3
or release 4. Now somewhere there is a directory called graphics for
the mapgen stuff and under that directory there should be a header
file graphics.h. That's the one you want to be easily available to
the Makefile under */mapgen. Above releases refer to mapgen release
codes.
Granted, damn confusing.
As and alternative, you could grab the mapgen stuff from charon.er.usgs.gov
and do it's install. At least I know where everything is there. But I
don't know if there are not some program renamings under GRASS.
I'm going to put this response on grassu to see if I can shake CERLs
chain to fix this problem.
Does someone responsible for putting mapgen into GRASS distribution have
a more appropriate solution. I keep seeing this message over and over.
Gerald (Jerry) I. Evenden Internet: gie@charon.er.usgs.gov
voice: (508)563-6766 Postal: P.O. Box 1027
  fax: (508)457-2310 N.Falmouth, MA 02556-1027
