MAPGEN
Jill,
You might want to post this message to the SCS gis bulletin board as well
as send it to analysis, am, etc...
Ken Sibley
PS - Good info to know.
From grass-lists-owner@max.cecer.army.mil Fri May 6 15:38:12 1994
Date: Fri, 6 May 94 15:12:28 CDT
Sender: grass-lists-owner@max.cecer.army.mil
Reply-To: grassu-list@max.cecer.army.mil
To: ngardner@ncrds.er.usgs.gov, grassu-list@max.cecer.army.mil
Subject: Re: MAPGEN
Cc: jschuler@ncg.scs.ag.gov
Content-Length: 3033
%%%----- Begin Included Message -----
%%%Our version of Mapgen4.1 will not work when we
%%%are using a Latitude and Longitude Projection.
%%%The following text demonstrates the process going into the
%%%interface.
%%%When setting up the location we responded to
%%%the question concerning ellipsoid as sphere.
%%%This is what the DEFAULT_WIND looks like:
%%%rncrds0:34> more DEFAULT_WIND
%%%proj: 3
%%%zone: 0
%%%north: 33N
%%%south: 32:52:30N
%%%east: 92:45W
%%%west: 92:52:30W
%%%cols: 2500
%%%rows: 2813
%%%e-w resol: 0:00:00.18
%%%n-s resol: 0:00:00.159972
%%%Creating PROJ_INFO & PROJ_UNITS with
%%%g.setproj works fine, here are the PROJ_INFO & PROJ_UNITS file:
%%%rncrds0:35> more PROJ_INFO
%%%name: Latitude-Longitude
%%%proj: ll
%%%ellps: sphere
%%%rncrds0:36> more PROJ_UNITS
%%%unit: degree
%%%units: degrees
%%%meters: 1.0
%%%When going to mapgen for the first time with
%%%An error occurs, which allows us to go no furthur:
%%%The PROJ_INFO file for Location <long_lat_test>
%%%is not in the correct format.
%%%Please run the command g.setproj from the PERMANENT mapset.
%%%EXITING ..........................................
%%%Is it possible that our errors come from the way the software
%%%was loaded onto our system?
%%%We would also like to know if there is a driver for either
%%%the Calcomp 1044 or the Calcomp 5800 Series Plotters for
%%%mapgen4.1 .
%%%----- End Included Message -----
> The MAPGEN documentation states that g.setproj should add '"es" or "e"
> and "a" values' to the PROJ_INFO file. However, it does not.
Unfortunately, at SCS we very seldom use the LL projection.
When I revised the mapgen4.1 script for compatibility with Jerry's
mapgen4.0, I assumed incorrectly that all PROJ_INFO files would record
the same information. Other projection's PROJ_INFO files set a and es
ellipsoid parameter values.
The LL PROJ_INFO file does not record this information.
If you must work in LL then manually add the es and a values to the
PROJ_INFO file. The values and format for the PROJ_INFO file are:
proj: ll
ellps: sphere
a:6370997.0
e:0.0
The 4.12 mapgen interface is not fully functional with a LL mapset. You
will not be able to use the make.fill command in lat/long.
Give me a buzz back if you have any more problems.
Sincerely,
Jill
# # #### #### #### ###### #### ##### Jill R. Schuler
# # # # # # # # # # USDA
# # #### # # #### ### #### # #### Soil Conservation Service
# # # # # # # # # # National Cartography and
# # # # # # # # # # GIS Center
#### #### #### # # #### ###### #### P.O. Box 6567
                    Ft. Worth, TX 76115
e-mail: jschuler@ncg.scs.ag.gov Phone: (817) 334-5559 x3086
