matching maps
hello,
  I am currently working on a series of maps all based on the same basin.
  As such when all the maps are finished their watershed boundaries must
match exactly for calculational purposes.
  Of course after the maps have been digitized the boundaries do not
match exactly. Until now we have been using mask and a short script to match
the two maps boundaries and to expand any delineations to the new map edge.
  I was wondering if there was any more precise and standardized way of
conducting this matching of basin boundaries or if the method we currently
use is as good as things get.
Thank you for any and all help,
Tom Meixner
"Tom Meixner" (tom@hwr.arizona.edu) writes on 30 Jun 93:
this info doesn't do you much good now, but for others' benefit:
whenever possible, trying to digitize the boundary of something first.
Then, g.copy this file and try to register it before you begin
a new set of features. E.g., Texas has boundaries that I would not
want to digitize more than once:
  g.copy vect=boundary.tx,counties.tx
  v.digit (counties.tx)
  g.copy vect=boundary.tx,riverss.tx
  v.digit (rivers.tx)
--Darrell
