mercator projections
Hello,
Is anyone a mercator projection location with GRASS?
I am trying to create a new location in a mercator
projection and I am not having much luck.
In setting up the new region, GRASS asks me for the
units and a conversion factor to meters. The units
for a mercator projection are degrees. Does GRASS
convert the degrees to meters? And the conversion
factor is different for lat and lon. I am confused.
Has anyone successfully done this?
Thanks.
-Stephen Dzurenko
Ocean Mapping Division
Ocean Technology Center
Graduate School of Oceanography
University of Rhode Island
ph: 401 792-6853
fx: 401 792-6849
e-mail: steve@ocean.oce.uri.edu
"Steve" == Steve Dzurenko <steve@ocean.oce.uri.EDU> writes:
    Steve> Hello,
    Steve> Is anyone a mercator projection location with GRASS? I am
    Steve> trying to create a new location in a mercator projection
    Steve> and I am not having much luck. In setting up the new
    Steve> region, GRASS asks me for the units and a conversion factor
    Steve> to meters. The units for a mercator projection are
    Steve> degrees. Does GRASS convert the degrees to meters? And
    Steve> the conversion factor is different for lat and lon. I am
    Steve> confused. Has anyone successfully done this?
    Steve> Thanks.
    Steve> -Stephen Dzurenko
    Steve> Ocean Mapping Division
    Steve> Ocean Technology Center
    Steve> Graduate School of Oceanography
    Steve> University of Rhode Island
    Steve> ph: 401 792-6853
    Steve> fx: 401 792-6849
    Steve> e-mail: steve@ocean.oce.uri.edu
Steve,
I've digitized, in GRASS 4.1.3, some NOAA charts which used the
Mercator projection. When setting up the GRASS location, I specified
the `merc' projection and GRASS asked me for an ellipsoid, a ``Central
Meridian'', and a ``Latitude of True Scale'' (these are in quotes
because I'm not sure what they mean). I used the *default* central
meridian and the ellipsoid and latitude of true scale specified on the
chart. After all that, it asked be for the ground units, which I
chose to be meters. I was later able to reproject the digitized charts
into UTM and state plane coordinates without difficulty. I can't tell
you how GRASS deals with the projection internally, but for me it
seemed to work.
Hope this helps.
Bill.
Bill Perkins
Battelle Pacific Northwest Laboratories
Environmental Sciences Center, Subsurface Flow and Transport
P.O. Box 999 MSIN K9-36
Richland, Washington, USA 99352 (509) 372-6131
wa_perkins@pnl.gov
