Modify r.ppm to read pgm files
I recently started experimenting with the r.ppm routine in src.contrib .
It is set up for PPM file, that is a three band color image with
magic number 6. Has anyone modified this to read a straight [0-255]
grayscale raster in PGM format, magic number 5? We regularly
produce rasters and can easily transform to PGM. Otherwise I
have to convert to ASCII and bring it in that way. (There might be
an obvious workaround, but I haven't turned it up yet.)
Also, wouldn't it be nice if there was a way to put the header in
one file and the raster in another. I had a LULC file for the entire US
that practically filled my disc and had to try to cat and append this
dinky 14 line header. Then when I had to make a change it nearly
killed my editor trying to handle the 17-zillion line file.
Tim Szeliga
tim@snow.nohrsc.nws.gov
